Vibration / rear prop-shaft
Post by Muzorewa » Mon Jun 15, 2015 7:09 am
Five years and about 85,000 miles ago, our Bongo developed a bad vibration which made it almost undriveable. There was a right clunk going from forward to reverse gears too and it all pointed to the rear prop-shaft. Sure enough, new (recon) prop and it was as good as new.
Because of that, when we were deciding on the spares to take with us on our epic trip of Iberia last year, (details HERE in case you’ve been on another planet) a rear prop was on the list, so we got one from George at Bongo Spares and squirrelled it away in the back of the Bongo along with an alternator and several tins of Spam.
Iberia went like a dream, well we didn’t need the prop anyway. Then on Saturday I noticed a really odd vibration coming through the steering wheel, not side-to-side but vertically, and only between 25 and 30mph so you could drive through it but clearly something was amiss. This pointed to something in the front transmission, maybe the front prop(s) or centre bearing, or the front axle. Or to do with the unevenly-wearing front tyre situation I’ve had since we got the Bongo.
So, over to Ady’s for a look. Swapped front wheels for different ones, that didn’t eliminate it. Checked all the play in the various components of the front drive and none were worse than Ady’s 4WD. Took the rear prop off and, ahem, there be the problem again....
....no idea now whether that one was new or a recon or just a serviceable secondhand one but it’s dead now. The new one for all that is only a serviceable secondhand one so I’ll be getting another from George shortly to stop the Spam rattling round in the back.
Odd for a defect in the rear prop to show up having been transmitted through the front transmission and through the steering column. Very odd.
I know it seems bizarre carrying things like that around but you never know. Be prepared. DYB DYB DYB etc :wink: And thanks again to Vanessa :D
Re: Vibration / rear prop-shaft
Post by rita » Mon Jun 15, 2015 9:11 am
Providing the yoke is not damaged why not fit a Hardy Spicer with a grease nipple .
Post by Muzorewa » Mon Jun 15, 2015 10:06 am
Could do, although that assumes someone is going to crawl underneath from time to time to do routine maintenance :oops:
Post by rita » Mon Jun 15, 2015 11:36 am
You should already have a grease nipple on a prop shaft , you could do both at the same time.( Two birds with the same Gun)
:D
Post by Muzorewa » Mon Jun 15, 2015 11:40 am
Indeed, the spline joint does have a greasing point. But that doesn't mean it gets used from one year to the next :(
Post by rita » Mon Jun 15, 2015 11:52 am
Muzorewa wrote:Indeed, the spline joint does have a greasing point. But that doesn't mean it gets used from one year to the next :(
Sorry don't really understand that point..
The splines allow the prop shaft to vary in length as the axle / components move they can get severely damaged if not properly look after IE greased.
Driver+Passengers
Post by Driver+Passengers » Mon Jun 15, 2015 12:10 pm
I feel sheepish just reading that. :/
Image Image
Post by Northern Bongolow » Mon Jun 15, 2015 9:34 pm
we looked at replacing part of the joint/cup /cross piece but as is the modern way they are crimped in with a machine,not like the good old days with the grove and circlip jobbies #-o #-o .
ps the new one got some grease in it. mind you by next service it may have another 20,000 miles on it.
whats the mileage up to to now muz ??.
Post by Northern Bongolow » Mon Jun 15, 2015 10:20 pm
some interesting chat on phasing props.
http://www.mgexp.com/phorum/read.php?1,1621395
mikeWalsall
Post by mikeWalsall » Mon Jun 15, 2015 10:52 pm
You used to be able to buy kits for staked in UJ's made by Moprod (?) .. dunno if you still can ..
I have one (some where) that I used on my Ford Cortina's propshaft back in the 1980's !!
There is a specific way of replacing .. so as to keep the integrity of the shaft balanced to eliminate vibrations ..
Post by rita » Tue Jun 16, 2015 10:38 am
Yes you can purchase universal joints to replace the Staked Type, they use Snap Rings on the side of the cups.
Post by Muzorewa » Tue Jun 16, 2015 7:48 pm
Northern Bongolow wrote:whats the mileage up to to now muz ??.
Just coming up to 365,000km. Was 83,000 when we got it and the rear prop that was on (maybe the original) took it up to 230,000. Then a replacement was fitted that could have been just a good s/h one or a service-exchange that took it to its present score.
Our Bongo is 4WD but also has the LSD, so it's absolutely cool (almost) on snow & ice and muddy fields but there's something curious going on with the viscous coupling because it castellates the front tyres over time. If the exit for the energy build-up is a new rear prop every few years, I'd rather that than have to replace an axle or autobox.
And to think that I hadn't driven a Bongo until I drove this one away from Imperial's showroom, and I just thought that if it didn't work out I could sell it and buy something sensible. It's been the best vehicle we've ever had by a very long way and has taken us to places we would never have seen any other way.
Bongoplod
Post by Bongoplod » Tue Jun 16, 2015 11:33 pm
Wow,and wow again....226800 miles =D> =D> =D> =D> =D> =D> =D> =D> =D>
How many times to the moon is that??
Anyone beat that ?????
Brian
Post by Simon Jones » Wed Jun 17, 2015 12:02 am
Can't top that with my Bongo, but my 'normal' car is catching up. An impressive mileage you have there Muz =D>
Post by Northern Bongolow » Wed Jun 17, 2015 1:11 am
Bongoplod wrote:Wow,and wow again....226800 miles =D> =D> =D> =D> =D> =D> =D> =D> =D>
Brian
the only 2 original things in the bongo though are the radio aerial and the driver :^o :^o :^o 8)
