Thought I would check my egr pipe today while I was checking oil ect. Found the pipe at the egr end, which had already been cut, or chewed off by a rat , but had not been blanked off. So where do I find the take-off point from the manifold ? I had a good poke around but could find nothing on either side of the engine. Could someone point me in the right direction ?
John B
egr again
- dandywarhol
egr reply
Thanks Dandy,
Am now slightly confused, cos if the egr is electrically operated what does the rubber tube do?
John B
John B
EGR
Thanks Ian,
I had thought that the egr ran off the inlet manifold creating a vacuum so by cutting the tube it would have left one end flailing around sucking fresh air.
Thanks guys.
John B
Thanks guys.
John B
- dandywarhol
Re: EGR
It would, but via the solenoid..........johnb8840 wrote:Thanks Ian,
Thanks guys.
John B
