Oil pressure gauge
the.sasquatch
Oil pressure gauge
Post by the.sasquatch » Fri Jun 12, 2015 9:19 am
Hi All, I am have been fitting some extra gauges to my Freda to help keep an eye on the engine and cooling system. I've already got my water and oil temp gauges installed and working but i'm not sure where to fit the sender for the oil pressure. is there a spare port on the block that is blanked off that i could use or would i be best to use the original sender location? I have an oil line and T piece so I can remotly locate.
Andy
helen&tony
Re: Oil pressure gauge
Post by helen&tony » Fri Jun 12, 2015 12:08 pm
You will have to plumb in a remote "T" piece, as there is no clearance on the block to add a "T" in situ, because of the block casting. I have oil, and a fair few gauges....errr....about 12 so far :lol: :lol: :lol: ...probably more coming!
the.sasquatch
Post by the.sasquatch » Fri Jun 12, 2015 12:13 pm
helen&tony wrote:Hi
Thanks, thats what i figured. I'm going to try and get it fitted at the weekend hopefully shouldn't be too much trouble to get it done 8)
Andy
helen&tony
Post by helen&tony » Fri Jun 12, 2015 12:35 pm
Yo might find the thread on the block tricky , as you'll need a hose with the right fitting to screw into the block.I use braided stainless and I have my sender strapped to the chassis, and the oil light "T"d off it . I was originally supplied with a hos that did not have a taper-fitting, so be careful...I believe mine was 1/8 NPT for a Subaru Imprezza, but you'll have to check. If you don't have a supplier, I can recommend one via P.M.
the.sasquatch
Post by the.sasquatch » Fri Jun 12, 2015 1:33 pm
Yeah it looks a bit tricky to get at, I've got a hose left over from a previous project and i'm pretty sure it's got the right thread.
All going well i should have them all in and working saturday afternoon.
Andy
Post by rita » Fri Jun 12, 2015 1:45 pm
Hi Andy,it might be worthwhile looking for another take off point, these are sometimes allen plugs, on you engine (presuming its a Diesel) I would look on the n/s of the block towards the front of engine .It might be inline with the original oil SW.
Good Luck.
the.sasquatch
Post by the.sasquatch » Fri Jun 12, 2015 2:11 pm
rita wrote:Hi Andy,it might be worthwhile looking for another take off point, these are sometimes allen plugs, on you engine (presuming its a Diesel) I would look on the n/s of the block towards the front of engine .It might be inline with the original oil SW.
Good Luck.
Thanks, will take a look. It is indeed a diesel, I did have a quick look the other day and didn't spot anything but will have a proper dig around at the weekend
Will let you know how i get on.
Andy
