Speedo Pulse Wire? Which Wire?
Mark Elvin
Post by Mark Elvin » Tue Jun 09, 2015 9:07 pm
Fitting my Waeco cruise control & I do not have a speed conversion chip fitted. I'm trying to identify the pulse wire for the speedo, I'd rather get the right one first time than have several attempts. Does anybody know which wire in which plug on the back of the instrument panel is the speedo pulse please?
Thanks in advance
Re: Speedo Pulse Wire? Which Wire?
Post by g8dhe » Tue Jun 09, 2015 9:21 pm
Its the Blue/White and White/Yellow on the 1C and 1A pins;
Post by Bob » Tue Jun 09, 2015 9:22 pm
From memory its blue/white, and the one obviously behind the speedo - there is another one the same colour behind the binnacle.
Hope that helps.
Post by Simon Jones » Tue Jun 09, 2015 10:20 pm
SP+ on the instrument panel PCB should also work. That should be where the blue wire goes in this picture where a chip has been fitted:
Mark Elvin
Post by Mark Elvin » Tue Jun 09, 2015 10:22 pm
Sorted it. :D
It's the Blue & White that feeds into SP+ on the back of the speedo.
Cruise works at treat.
Post by Bob » Tue Jun 09, 2015 10:23 pm
Nice one. =D> =D> =D>
cmm303
Post by cmm303 » Wed Jun 10, 2015 1:36 pm
Mark Elvin wrote:Sorted it. :D
for future readers, this is the blue/white wire in the wider connector that plugs into the central socket on the PCB. (I also had a blue//white wire on the left hand connector)
Chris with BertieB
Mark Elvin
Post by Mark Elvin » Wed Jun 10, 2015 1:40 pm
I picked up using a ring terminal under the SP+ screw, saved chopping into the loom.
