I have had difficulty stopping my AFT from groaning and creaking especially on the way down. I think it is because some of the white nylon rollers are seized and this would explain why it is sensitive to the tilt of the van.
I have tried all sorts. Spray on grease did quite a good job but in hindsight that is probably because it also lubricated the surface of the rollers. Last night I tried spray oil with Silicone (as used on Mountain Bikes). There are still some rollers not going round. I tried freeing one of the small exposed rollers that does not seem to do much and no amount of spraying and wiggling with pliers freed it. So I don't hold out much hope for rollers that are buried in tracks. I didn't try penetrating oil as I thought this goes sticky as it dries.
Should I just grease up the tracks and give up hope of the rollers all rolling? Or maybe there is a magic spray?
Groaning AFT
Groaning AFT
Chris with BertieB
Re: Groaning AFT
Plumbers silicon spray ?
Mine gets a good spray regually on rollers and moving parts hinges etc
Good for zips as well
Re: Groaning AFT
ThanksGasy wrote:Plumbers silicon spray ?
I've got some silicon spray, used to reduce mud sticking to bike. Not tried it. Same as the plumbers version? Excellent for curtain rails also!
Chris with BertieB
- the1andonly
- Tribal Elder
Re: Groaning AFT
you wont have a silicon spray
it will be be silicone
the snatcher thatcher showed herself as the most inept chemist (BSc) confusing the 2 on telly
clean all surfaces, track rollers etc with your favorite solvent. shift any oil grease dust etc no WD40
A mountain bike summer lubricant (red bottle) is a good choice, (contains PTFE and water)
Finish Line Teflon Plus Dry Lubricant
http://www.tredz.co.uk/.Finish-Line-Tef ... tAod0igAhg#
ps I have the joy of dealing with Silicon (eutectic die attach for the google miesters) and silicones (try Dow Corning)
on a daily/ regular basis.
