Where does the temp sender hide on engine.
I have seen a photo from Bongo fury, with a red circle on near side of engine at the front. But i have not been able to find it. Thanks, hoping some one knows where. Regards Rallyman, Essex
- haydn callow
Re: Where does the temp sender hide on engine.
Which engine do you have???
Diesel temp sender is on the offside under drivers seat
- Simon Jones
On the diesel engine for instance, there are two sensors: one for ECU and one for the temp gauge. Which one are you interested in?
Hi Doone, I am looking for the temp sender,i have found one at the top front of engine, under top by gear selector. Engine is 2.5 turbo dieselSimon Jones wrote:On the diesel engine for instance, there are two sensors: one for ECU and one for the temp gauge. Which one are you interested in?
haydn callow wrote:Which engine do you have???
I you are looking for the temperature gauge sender/transmitter you have found it ,if you are looking for the ETC sensor it is the one on the o/side of the engine towards the rear.
Just replaced my sender,if you need to do it this may be helpful.
http://igmaynard.co.uk/bongo/forum/view ... =3&t=69358
