Waterless Coolant
Waterless Coolant
Post by Ian » Wed May 20, 2015 9:47 am
So what do people reckon about this?
https://youtu.be/ZQk_X33B2iQ
Technical info is available from the manufacturers at http://www.evanscoolants.co.uk/
Gimmick? Or scientific breakthrough?
andyb36
Re: Waterless Coolant
Post by andyb36 » Wed May 20, 2015 11:08 am
I would try it it mine
I bet similar stuff has been around for a while
if it doesn't get that hot etc - how would that effect the bongo,s bleeding method and having air locks ?
I guess that would also eliminate any corrosion that could be happening right now in your system
lots of questions
andy :shock:
mikeWalsall
Post by mikeWalsall » Wed May 20, 2015 11:20 am
A lot of Japanese manufactures already use water less coolant as standard ..
Toyota have used 'Toyota red' for years .. my own opinion (for what it's worth) .. remove it and use a good quality 'normal' UK anti freeze as then you know what is in the system .. and now what it as been topped up with ..
Unless you thoroughly flush the old stuff out and do a total re fill then be careful ..
Why .. ?? waterless anti freeze is not compatible with .. water .. and can turn into none efficient jelly ..
Post by g8dhe » Wed May 20, 2015 11:23 am
Given the frequency of leaks from coolant pump, radiator and pipes, I guess you would need to carry a few litres of the liquid in the van at all times in case there is a loss ? Perhaps a bottle fitted permanently in the front ?
Post by mikeonb4c » Wed May 20, 2015 2:34 pm
g8dhe wrote:Given the frequency of leaks from coolant pump, radiator and pipes, I guess you would need to carry a few litres of the liquid in the van at all times in case there is a loss ? Perhaps a bottle fitted permanently in the front ?
Aye Geoff, that's the problem :-(
helen&tony
Post by helen&tony » Wed May 20, 2015 3:13 pm
Second that :lol:
briwy
Post by briwy » Sat May 23, 2015 8:52 pm
And it's expensive :(
ELZE
Post by ELZE » Sun May 24, 2015 6:17 pm
surely standard anti freeze coolant is the way to go, any weaknesses shows up and it leaks right. If you have £90 a go stuff in and get a leak you have an expensive problem.
There's no guarantee any system will not develop leaks or faults irrespective of what you put in it.
