Key problems help
Key problems help
Hi I have a Bongo Nreg auto diesel, When I put the key in and start it starts first time runs lovley, however when I put the auto gear lever in park the key wont release is there anything I can do or do I need a garage??? any help will be appreciated.
Re: Key problems help
this is how the key interacts with the gear cables, usually a plastic clip at the end of the cable breaks or drops off.
sometimes a wobble of the stick helps, also a foot on the brake peddle is involved when selecting a gear so try that also.
the key barrel itself is known to wear and need replacing.
Thanks, ill have a play. Is it easy to replace the bit if it is gone?
it depends whats gone
. see if you can get the key out in any gear or neutral.
