Hi guys, my n reg bongo is making a rather loud noise which appears to be coming from the nsf wheel, it 4 wheel drive so I presume the bearing,
Now a while back I was looking on ebay and I'm sure I saw nos hub complete with bearing, if so does anyone have a part number for this and is it still available from the dealer, if not can anyone recommend a good bearing or anything else to check for
Wheel bearing
Re: Wheel bearing
Big difference in price from a hub assy to a replacement bearing
Re: Wheel bearing
Yeh thought so, the one I saw on ebay was very cheap, wish I'd of bought it now
Re: Wheel bearing
get it checked properly by jacking up 2 wheels on the same side (if its not rear limited slip diff) then spin the front wheel, it could be several things on the same shaft, could be wheel bearing or drive shaft or front diff bearing or diff itself, dont want you replacing stuff thats not needed.
this guy will sell you the front nearside corner complete.
give him a call.
http://www.bongospares.co.uk/
front diff.
front shaft.
front hub and bearing.
give him a call.
front diff.
front shaft.
