High temperature /low coolant alarm opinion
cushers
Post by cushers » Mon May 18, 2015 8:28 pm
Hi All,
Saving the pennies to buy one of thee Haydn setups. I was intending getting the clock/readout system that's housed in an audio DIN cuddly. Unfortunately the wife has laid claim to the cuddy and I was wondering where else others mount the display. Anyone managed to have it in front of the instrument binnacle? Anywhere else?
Graeme
Re: High temperature /low coolant alarm opinion
Post by mikeonb4c » Mon May 18, 2015 10:23 pm
cushers wrote:Hi All,
Graeme
Interesting question. I have a TM2 and have yet to fit it. I've not been able to decide where it may be fitted unobstrusively - I'm not into loads of bright digital displays in full view of me and (more importantly) my passenger. I'll be interested to read what people say.
Harry Monster
Post by Harry Monster » Tue May 19, 2015 1:50 pm
I saw a picture where someone had mounted it underneath the electric blind switches, next to your left knee. You can see it easily through the steering wheel. I've already mounted mine in a BMW cubby clock thingy, wish it hadn't now as I think this is a better space. Problem with them being mounted higher up is if sun shines on it you can't see the numbers :-(
99 2.5td, 2wd, AFT & Rear conversion with the funky swivel seat!
cushers
Post by cushers » Fri May 22, 2015 9:33 pm
Cheers Harry M
Post by mikeonb4c » Fri May 22, 2015 9:50 pm
Harry Monster wrote:I saw a picture where someone had mounted it underneath the electric blind switches, next to your left knee. You can see it easily through the steering wheel. I've already mounted mine in a BMW cubby clock thingy, wish it hadn't now as I think this is a better space. Problem with them being mounted higher up is if sun shines on it you can't see the numbers :-(
Interesting. I'd come round to thinking that might be a good position. Thanks for the tip.
Post by Simon Jones » Fri May 22, 2015 11:17 pm
I've mounted my TM2 and TM4 into case which fits in the top of the cubby hole. It's a short term solution until I make a smaller dedicated unit to contain them.
You can just make it out at the bottom of this picture. The unit on top was something I was toying with the idea of fitting to contain the temp gauges and some other switches, but that project has been shelved for now.
