fuel pump leak
steveandmary
- Bongonaut
fuel pump leak
Leaking seal on fuel pump . any fact sheets and ware can i get packet of new seals from . thanks
Re: fuel pump leak
Fact sheet in the members area and seals available in the club shop.
Re: fuel pump leak
have you tried to nip up the side seal bolts, both back side and front, sometimes this is enough.
another fix that sometimes works is run the fuel tank to nearly empty then add a tea spoon full of glycerine, available in small amounts from chemists. this can swell the seals so stop the leak. cheap fix if it works, it did for mine.
- Simon Jones
Re: fuel pump leak
I've got a pair of brand new seals for £5 inc postage if they're any use to you. Not sure what the two nuts are for but they came in the same box of spares so you get those for free
- The Great Pretender
Re: fuel pump leak
Leaking from where, sides, front or back?steveandmary wrote:Leaking seal on fuel pump . any fact sheets and ware can i get packet of new seals from . thanks
To infinity and beyond
