Haydn Coolant Alarm Still Driving Me Nuts....
Mark Elvin
Post by Mark Elvin » Sat May 16, 2015 6:45 pm
OK,
The alarm sounds continuously whether it be engine on or just ignition on, the alarm does not stop
There is coolant in the tank, the battery is new.
I can get the alarm to stop by shorting screw in the header tank to earth, but a few seconds later it restarts.
The screw was cleaned only three months ago, surely it's not really realistic to expect the screw to be cleaned any more frequently than that as it means dismantling the LB installation to access the screw.
Anybody got any more suggestions?
Tony x
Re: Haydn Coolant Alarm Still Driving Me Nuts....
Post by Tony x » Sat May 16, 2015 8:05 pm
I know Haydn uses a particular type of stainless screw (marine grade I believe) and lesser stainless screws can cause the problem you describe. You could get a new screw, particularly if it is not the original... - personally, I'd go for titanium as that stuff is many times more corrosion resistant than anything else - all those surgeons can't be wrong.
Expect to pay £10, titanium is around 2000x the cost of steel to make.
This could be overkill.
Post by g8dhe » Sat May 16, 2015 8:15 pm
When did you last put fresh anti-freeze in? Its that which lays down the coating for a while after its put in.
Darkstar
Post by Darkstar » Mon May 18, 2015 8:15 pm
Has he earth wire come adrift?
http://enginewatchdog.com/tm2%20installation.html
Trouble shooting section at bottom of page
Got a Bongo for the Wife, Best trade-in ever
Post by haydn callow » Mon May 18, 2015 9:20 pm
What voltage are you getting between the screw head and earth.....should be +/- 1.8 volts.
If you had new red coolant 3 months ago.....give the screw a good clean......that should cure the problem for good....or contact the webshop for a free replacement screw.
Post by haydn callow » Mon May 18, 2015 9:28 pm
Darkstar wrote:Has he earth wire come adrift?
We are dealing with a coolant alarm here.......that link is to a temp alarm.
Mark Elvin
Post by Mark Elvin » Tue May 19, 2015 9:25 pm
New screw fitted today, plus extra screw as suggested.
All fixed, despite me disbelieving.
Many thanks for your help
Darkstar
Post by Darkstar » Wed May 20, 2015 1:14 pm
Something new learned.
Post by haydn callow » Wed May 20, 2015 2:30 pm
Actually nothing to do with a loose earth........putting a new sensor screw in is what corrected the fault.
The way these alarms work is that a small voltage/tiny amp currant is put into the cooling system via the sensor screw, this currant then goes to earth via the coolant to the engine block. The alarm is triggered when the coolant level drops below the sensor screw breaking the circuit.....the lack of coolant causes the resistance to rise, the alarm puts in more volts until the 2.8 volt trigger is reached.......simples!!!
However anything else that causes the resistance to rise will also trigger the alarm..ie..coating on the screw/ weak coolant.
There is no need to fit a second earth screw into the header tank. If doing this sorts out the problem it is masking a underlying problem.......
Try disconnecting thr second screw from earth......the alarm should work perfectly.
Mark Elvin
Post by Mark Elvin » Wed May 20, 2015 3:16 pm
Mine was repaired by jsut the single screw, but I added the second anyway.
Post by haydn callow » Wed May 20, 2015 4:43 pm
The second screw will not do any harm, it's just not required on the latest model alarm,
