Accessing Rear O/S Blind Mechanism
notlob
Post by notlob » Fri May 08, 2015 10:55 pm
Hi All,
My o/s rear blind has seized. it doesn't work on the switch and can't be moved by hand, so I want to have a look at the operating mechanism but have no idea how to get to it.
Assume I'll have to remove all the trim, but how is it fixed. Unbolt the split rear seat, seatbelt mounts and grab handles but how is the rest attached?.
Any help would be appreciated.
Dave
Cab-ova pete
Re: Accessing Rear O/S Blind Mechanism
Post by Cab-ova pete » Sat May 09, 2015 10:41 am
Hi all, I am having the same problem with my window blind behind driver, it will mean be up/down manually but no movement using switch,where is the first place to start? Sorry I have no answer for your question Dave? You remind need me of my next project :? Hope you sort it!
Post by g8dhe » Sat May 09, 2015 10:53 am
