Aft roof liner.
zippy
Aft roof liner.
Post by zippy » Mon May 04, 2015 7:40 pm
Can you removed the liner?
Need to do some roof mods.
Toyota Alphard - Bongo spirit
Re: Aft roof liner.
Post by Simon Jones » Mon May 04, 2015 8:14 pm
zippy
Re: Aft roof liner.
Post by zippy » Mon May 04, 2015 8:24 pm
nice info, but i only need to remove the inside roof felt.
Possible to remove the felt roof liner?
Going to be attaching a 200w solar panels :)
Re: Aft roof liner.
Post by g8dhe » Mon May 04, 2015 8:51 pm
Why would you need to remove the liner if fitting panels? The rear of the AFT is outside of the tent and you cab bring the cable's down there without entering the AFT tent at all, even a nice grommet to feed the cable down into the vehicle.
Dodgey
Re: Aft roof liner.
Post by Dodgey » Sat May 16, 2015 10:21 am
... and if you install panels further up the roof (only do this with thin light panels) then mount them so the cable exits at the side then it can go through the roof between the tent and the lifting rail. No need to go inside the tent.
