I have a '95 Diesel which has been running fine all winter. Recently I have been noticing that the glow plug relay going nuts as the engine reaches running temperature (on, off, on, off etc) when idling. So I added it to my to do list, and moved on...
Now when trying to start it up, around and below 5oC the rad fans spin up before I even turn the engine over, and once started it coughs and splutters for about 20 seconds and dies. As far as I can hear all the "clicks" are happening when I turn the ignition on, but with my head in the cab and the rad fans on, I can't hear the glow plug relay.
From what I have read, it is looking like the coolant temp sensor under the cold start solenoids is the culprit, but before I start dismantling anything, I was wondering if anyone has had similar and can confirm. Also, as it's the coolant temp sensor, I am guessing that I will need to bleed the system again after changing it
