Fog Light Repair or Replace
Moderator: Ian
khisanth
Post by khisanth » Wed Apr 29, 2015 12:48 pm
I have a set of fog lights fitted i took the driver side off to clean as it was filthy on the inside as the latch to keep it closed was open. When i came back from hospital my dad had tried to lean the reflector housing but a lot of the reflective surface had come off.
What is the best way to repair this or should i try and get a 2nd hand one. Also on the same note does anyone know of a different type that might fit in the gap which i can get new. any help be greatly appreciated.
Below is a picture of the type of fog light (not my damaged one)
Gasy
Re: Fog Light Repair or Replace
Post by Gasy » Wed Apr 29, 2015 4:59 pm
I've got 4 small round spotlights which are going where the fogs are
There not dear to buy
winchman
Post by winchman » Wed Apr 29, 2015 5:15 pm
Some times it can be difficult to mount after market lights, just have a look and see how you could do it.
They are not expensive new
Have you considered spraying the reflector with Chrome spray paint? Not done it my self but I believe its very good, its about £7 in Wilcos
stuc
Post by stuc » Sun May 03, 2015 7:29 pm
I fitted Ring Roadrunners to my last one, they fitted quite well, just had to make brackets up. I would go Led route off Ebay, ther are some reasonable priced super bright lights at the minute.
Return to “Pimp My Bongo”
