Hi All
There may well be a simple answer to this question but as a new owner I'm on the learning curve! My Bongo has a side kitchen and rock and roll bed. I would kike to fit a set of middle seats for occasional use and obviously the standard (3 seater?) width will not fit? Are there any two seater width standard Bongo seats available?
Thanks in anticipation!
Missing middle row of seats
Re: Missing middle row of seats
Hi, greetings, can't answer your question as I'm also a newby
just a warm welcome! I'm sure someone will answer you shortly, plenty of info available. Where are you n,s,e,w?
There are some converters who cut down seats to fit a side kitchen conversion, however, with a rock n roll bed I assume you have a nice flat floor. This would have to be cut up to fit seat rails and runners. As far as I know you cannot get a seat just to bolt in with a flat floor. I'm sure someone will come along and correct me though.
Alan & Dot
Yes sir, I can Bongo !!
Mini bus seats come in 2 seaters with seat belts attached ( get down scrapyard )
And the ones I used in landys fixed to flat floors
Only prob is with insurance I should think
