Willinton Charger
helen&tony
Willinton Charger
Post by helen&tony » Mon Apr 20, 2015 1:23 pm
I was just dropping the coolant to check out one of the steel pipes, when I looked at the light on the Willinton Charger on the LB...I seem to remember that when the LB is charged, the SB then gets a trickle off the Solar panel , as the Willinton kit allows charge to flow to the SB...is that correct?....anyway, the panel is going like a good'un...one of "Dodgey's" admirable kits....I don't normally see much charge, as the Bongo lives in the barn, but I pulled it out to avoid coolant all over the floor :lol: ...can't have the moggies supping coolant!
Re: Willinton Charger
Post by g8dhe » Mon Apr 20, 2015 1:56 pm
Some of the relays he used would sense the voltage on either side, not just the SB side, if its one of them then yes it will allow charging of the SB from a charger connected to the LB.
helen&tony
Post by helen&tony » Mon Apr 20, 2015 2:23 pm
Hi Geoff
Thanks for that...I guess mine must be one that does...I noticed the LED indicator on the C-Tek charging socket suddenly showing full charge, when it was previously indicating that it needed a top-up...hence the question, as I seemed to remember that the Willinton kit allowed a reverse charge, so to speak!...I must get the Bongo out sun-bathing more often, then!
