I read Haydn has a switch to turn off the glow plugs.
I put 4 new Blueprint ones in about 2 years ago and, a few days ago and following lumpy starting and running for the first few seconds, found 3 were duff. I've since replaced them and all is fine.
However, and unlike most diesels, the plugs stay on for a long time. I have a light on the dash that tells me when power is going to the glow plugs:-
I've had this for several months and note the plugs remain on for around 2 miles from a cold engine and about 5 seconds for a warm engine. Also, the plugs may initially go off and then come back on again shortly after but this is rare. Given that with 3 duff plugs, a cold engine would run fine after a few seconds, I reckon I could install a switch to help preserve the plugs (and maybe the plug relays which can cause problems)
I'm writing this post for 3 reasons
- Firstly, to draw other folks attention to this potentially useful and penny saving mod.
- Secondly, is there an alternative wire in which to insert the switch rather than by the relay itself. I ask this as I'd sooner find one in the cab area if possible. I read the temp sender on the head will do this but also turns the fans on so that's no good.
-Finally, I hear the glow plugs were designed to stay on for so long so as to reduce pollution in Japanese cities. As this problem is now overcome by moving the whole vehicle to Somerset, I can't see any reason not to try the mod but I welcome advice?
