My full DIY conversion
spawnedc
Post by spawnedc » Mon Apr 13, 2015 9:43 pm
Hi dear Bongo lovers!
Lots of things on this forum inspired me so I decided to do my own conversion. Not all finished yet, I had to take some time off because of my back problems. But finally, I picked it up on Easter weekend. All the parts are made by myself, including rock and roll bed. There will be some other improvements like Raspberry Pi 2 navigation/entertainment system once I'm done with these, but I'll post that in a separate thread.
I'd love to hear what you guys think about it. Any suggestions welcome :)
Here's the full photo album.
First photo:
And current state (will be updated with the latest):
Re: My full DIY conversion
Post by Simon Jones » Tue Apr 14, 2015 12:05 am
Wow, you've been busy and it's really coming along :). My top tip would be if you ever need to cut any more holes in the bodywork, get one of these: https://www.machinemart.co.uk/shop/prod ... al-nibbler
It will cut a thin accurate slot in steel without any distortion of the panel or damage to the paintwork. Whatever is used to cut a hole, all bare metal should be treated and a proper seal made using the double-sided gasket tape or good quality silicone sealant. This was one I did with red oxide primer:
This was one from a 'professional' conversion company and there is no protection on the cut edges. I ended up plastering it in Waxoyl as it was not possible to remove it to get to both sides:
spawnedc
Post by spawnedc » Tue Apr 14, 2015 9:16 am
Thanks Simon, very good point. Somehow my jigsaw couldn't handle it so I had to use my drill to do it. But I wish I knew about that nibbler. I'll definitely get it next time.
Also very good point on sealant. I should've thought about that. That will be my very first task once I'm back on the van.
For the next 2 weeks I will have some guests, so updates will be slow. But after that, I'm planning to go back to full speed :)
Thanks for the suggestions Simon!
Post by Bob » Tue Apr 14, 2015 3:50 pm
Looking very good. =D>
spawnedc
Post by spawnedc » Mon Apr 27, 2015 7:03 pm
Hello again,
This weekend wasn't very productive unfortunately. However, it was very annoying. I realised that I totally miscalculated the height of the seats, as I tried to sit on the seat with 3" (~7.5cm) thick foam was on it and my head was touching the ceiling (I'm 6 feet or 183cm). So I had to take all apart on Saturday and shorten the vertical supports about 9.5cm (3.75") which took the whole day.
On Sunday, I started preparing the bases for the upholstery (which I completely forgot to take pictures). After that I made the side panel with 2 doors, one is usaeable all the time, the other one is useable when the seat is in bed position. I also installed 2 basic locks to prevent the seats and the drawer from sliding when I hit the breaks. The one on the right hand side is quite noisy, which I couldn't anticipate. I need to wrap it with some plastic thing.
Not many updates for the last weekend, but hopefully, for the next weekend, with the help of bank holiday, I'm planning to finish off the cupboards and move onto the kitchen. Here are the pictures (I also updated the album on the first post):
Gasy
Post by Gasy » Mon Apr 27, 2015 7:19 pm
Don't forget to put a vent hole through the floor for your gas bottle
(in case of leaks LPG is heavier than air )
And a fixing strap
And a co alarm
Looking good
jimmo62
Post by jimmo62 » Mon Apr 27, 2015 7:45 pm
If you have electric blinds, don't forget to move the switch for the middle driver side window so you can operate the blind easily - I got a pre-converted Bongo and they had not done this which was a real pain to put right later!
spawnedc
Post by spawnedc » Mon Apr 27, 2015 7:49 pm
Gasy wrote:Don't forget to put a vent hole through the floor for your gas bottle
And a fixing strap
And a co alarm
Looking good
Thanks Gasy, those are in my todo list :)
jimmo62 wrote:If you have electric blinds, don't forget to move the switch for the middle driver side window so you can operate the blind easily - I got a pre-converted Bongo and they had not done this which was a real pain to put right later!
Luckily I don't have electric blinds :) But thanks for the heads up.
blobber
Post by blobber » Mon Apr 27, 2015 10:28 pm
Like the blue roller shutter rear door you've fitted to your Bongo :lol: :lol: :lol:
Alan & Dot
Yes sir, I can Bongo !!
spawnedc
Post by spawnedc » Mon Apr 27, 2015 10:31 pm
blobber wrote:Like the blue roller shutter rear door you've fitted to your Bongo :lol: :lol: :lol:
That's how I roll :lol: :lol:
spawnedc
Post by spawnedc » Thu Apr 30, 2015 9:51 pm
Unexpected Thursday update; lovely wife prepared all the seat covers, so all I needed to do was just staple it to the base :) Here's the result:
More to come this weekend!
zippy
Post by zippy » Thu Apr 30, 2015 10:40 pm
did you threat the naked metal from the electric hookup?
Looking good.
Toyota Alphard - Bongo spirit
silage
Post by silage » Fri May 01, 2015 7:42 am
looking very snazzy,
Gasy- co alarm? for what? and where?..............
" The harder you work, the richer you die"
97 4WD 2.5 TD
G0JZW
spawnedc
Post by spawnedc » Fri May 01, 2015 1:35 pm
zippy wrote:did you threat the naked metal from the electric hookup?
Looking good.
Not yet, but I just remembered the mains hookup came with the double sided casket tape and I used it. Would that be enough? Or should I do something from the inside as well?
Gasy
Post by Gasy » Fri May 01, 2015 2:58 pm
silage wrote:looking very snazzy,
To save your life
poisoning from fumes from gas cooker / heaters
There only about £20 nowadays
Get the ones where you carnt replace the batterys as they will need re calibrating by then in any case
I'd fit a smoke alarm aswell if I had cooking appliances in mine or sleeper in it
