Engine Flush on 1996 Diesel
manwithsound
Post by manwithsound » Mon Apr 13, 2015 9:40 pm
Hi all, I have a very noisy engine, very tappy and chuggy. I've done some research and what keeps coming up is the Tappetts/rods need a good clean hence the engine flush.
Has anyone in here had experience of this, am i on the right path or is this a common fault.
Your help would be greatly appreciated,
Jay [-o<
Re: Engine Flush on 1996 Diesel
Post by Northern Bongolow » Mon Apr 13, 2015 9:54 pm
can you record it and put a link on here for us to listen.
Titan1995
Post by Titan1995 » Mon Apr 13, 2015 11:19 pm
check that there is no wear in the rocker posts....I had a couple of broken fingers due to this .
Post by Simon Jones » Mon Apr 13, 2015 11:25 pm
I've used engine flush on a vehicle before and it made it worse by messing up the oil in the hydraulic lifters. The Bongo diesel engine has old fashioned rocker arms and I don't think any amount of magic oil treatment is going to help with worn parts or incorrectly adjusted valve clearances. I think you need to get your socket set and feeler gauge out to investigate this one.
manwithsound
Post by manwithsound » Tue Apr 14, 2015 1:22 am
Wow thanks for all the suggestion,
I'll upload a recording of it here. I love my Bongo (Frank) needs some TLC but i'm determined to get there :)
Thanks Again
Jay
Post by mikeonb4c » Tue Apr 14, 2015 8:20 am
I just had to have a new head fitted. One nice spin-off was that the engine is now much quieter now that I have a head with freshly adjusted rappers. :-)
Post by rita » Tue Apr 14, 2015 3:20 pm
Hi Jay, it would be worthwhile removing the rocker cover and giving the Cam Shaft a good examination, these old oil burners can suffer from fractured (broken ) cam shafts this would cause it to be both noisy and erratic(chuggy). Also make sure that the valve gear is getting a good drink, if all ok adjust the valve clearance.
Good Luck.
manwithsound
Post by manwithsound » Fri Apr 17, 2015 1:31 am
Hiya, thanks again for all the replies,
Well after long deliberation, and some expert advice. It seems that the engines on the 1996 diesel are naturally noisy buggers!!
However, a tappet adjustment was advised, i have my gauges ready but i'm unsure of the measurements and also if the tappets should be adjusted warm or cold?
Any help on this would a be a boon!
Thanks Again
J
mikeWalsall
Post by mikeWalsall » Fri Apr 17, 2015 9:38 am
Tappets are set cold ..
Inlet ... 0.1 mm (0.05 mm +/- tolerance)
Exhaust 0.2 mm (0.05mm +/- tolerance)
Post by rita » Fri Apr 17, 2015 9:49 am
manwithsound wrote:Hiya, thanks again for all the replies,
Thanks Again
J
Yes they are noisy ,but normally not Chuggy. :lol: :lol:
