Red antifreeze - caused problems with my low coolant alarm
langtoftnick
Post by langtoftnick » Mon Apr 13, 2015 2:49 pm
Just a note on my experience with antifreeze and haydn's low coolant alarm...
With red antifreeze in the system the alarm took about 2 minutes to shut up after starting the bus.
With blue antifreeze it stops virtually immediately.
The colour may, of course, be a red (hahaha) herring, but both were the same make and composition according to the bottle.
Re: Red antifreeze - caused problems with my low coolant ala
Post by Muzorewa » Mon Apr 13, 2015 3:07 pm
Contact Jo ( [email protected] ) she'll send you replacement screws for the header tank, that should cure it :wink:
Gasy
Post by Gasy » Mon Apr 13, 2015 5:53 pm
It's doing what it's supposed to do
It puts a protective coating on the inside of cooling system
So the screw gets a coating as well
Just remove and clean screws
Post by Bob » Mon Apr 13, 2015 6:11 pm
Yep, I just undid the screws, not fully out, clean with a small wire brush and screw back in.
Engine cold, obviously. :wink:
Post by haydn callow » Mon Apr 13, 2015 6:23 pm
It's normal for red coolant to do this for 2/3 weeks when first introduced into the system......as said...clean the screw or after a couple of weeks contact us for a new screw.
langtoftnick
Post by langtoftnick » Mon Apr 13, 2015 7:41 pm
Hear you all, cleaned the screws, got replacement screws, cleaned them, cleaned them again....problem for a year. Changed to blue.... Problem gone. Perhaps it was cruddy antifreeze.
