I have a 2WD Bongo that I am currently swapping the "Good Bits" onto my other Bongo.
I have removed the left had hub.
Does the 2WD hub have splines within it to take the CV joint of a 4WD.
I have managed to undo the very very tight blanking nut and it appears to have a shaft pressed into the hub.
I do not want to waste my time trying to remove this shaft to find that it does not have the splints.
There is a female thread on the outer side, I am wondering if this is just cap and screwing in a bolt will remove this and then shaft can be pressed out.
Front hubs 2WD
Re: Front hubs 2WD
does this help.
look like its a goer to me.
Re: Front hubs 2WD
It looks like the hubs carry a different part number, the rest of the assy should be interchangeable, why do you want to change (swap)the hubs.?
Good Luck
Good Luck
Re: Front hubs 2WD
There is no brake disc shield on the right hand side of my 4WD Bongo.rita wrote:It looks like the hubs carry a different part number, the rest of the assy should be interchangeable, why do you want to change (swap)the hubs.?
Good Luck
Looks like it is a press fit on the hub.
Was just looking to use the hub from the 2WD
