rocker cover gasket diy?
chipvan
Post by chipvan » Sat Apr 11, 2015 5:41 pm
Noticed we have to change ours,is it a day job?..take it require a touque wrench?
helen&tony
Re: rocker cover gasket diy?
Post by helen&tony » Sat Apr 11, 2015 7:13 pm
Easy job...most folk should do it in no time...I take time over everything...arthritic joints... :lol: :lol: :lol: ...Torque wrench...well...hand tight and a bit, and re-check in a while....I have torque wrenches, but only for the important bits!
chipvan
Post by chipvan » Sat Apr 11, 2015 9:18 pm
That's brill many thanks,will have to sort ...
chipvan
Post by chipvan » Sat Apr 11, 2015 9:25 pm
Do I have to remove the black centre section that covers the engine bay,where the centre console fits over?
Post by Northern Bongolow » Sat Apr 11, 2015 10:07 pm
yes.
the torque wrench is very important on this job as the bolts that hold the rocker cover on have a very thin steel tube round each one to help the gasket position correctly and to space the rocker cover from the head face. if these bolts are over tightened they may collapse slightly unevenly making the rocker cover uneven so the gasket will not seat evenly.
number 6 on this link. it doesnt show the tube but you will get them in the new kit.
helen&tony
Post by helen&tony » Sun Apr 12, 2015 5:12 am
Ady...
That's worth knowing re: torque...I don't think I tightened mine much more than finger -tight (with a bit of hylomar)...plus a wee tweak...probably not tight enough!
Post by rita » Sun Apr 12, 2015 12:44 pm
The torque settings.
5.0—8.8 N·m
{50—90 kgf·cm,
44—78 in·lbf}
