Electrics completely dead
Posted: Sun Mar 22, 2015 12:10 am
by Bongorolo
Would appreciate some guidance/help. My battery fully charged, terminals tight, fuses ok but no ignition lights etc when key inserted and turned. Yet to check the earth leads but as it was working last time out (Christmas time) wondered if there was anything else I should check?
Re: Electrics completely dead
Posted: Sun Mar 22, 2015 12:26 am
by the1andonly
remove terminals and check for corrosion and clean.
do other electrical items work
eg cigar sockect (if SB) or sidelights
Posted: Sun Mar 22, 2015 12:32 am
by Bob
Hi, and welcome.
I think I would still look to the battery since your Bongo hasn't been used in 3 months.
When you say, 'Fully Charged' have you put a charger on it? Was it left with a Maintenance Charger on it for that time?
With the charger removed what voltage is it reading?
Have you tried a booster pack or jump leads?
It is possible the battery has died over the lay up period but you think its been charged.
Really hope that's some help.
Posted: Sun Mar 22, 2015 10:52 am
by Simon Jones
Check fuse 4 (main) and 13 (ignition) in the fuse box under the bonnet.
Have you got an immobiliser which may have malfunctioned?
Have you got one or two batteries and what voltage(s) are you getting?
Do other electrical things like headlamps work?
Posted: Mon Mar 23, 2015 8:51 pm
by Bongorolo
Thanks everyone for the ideas - very much appreciated.
Battery still charged. (had used my Halford battery charger) Nothing at all working. So in line with the suggestions, went through the checking of the leads again, checked fuses and then remembered I had an earth isolator put on the main battery as the battery used to keep draining when standing for a long time. This had worked great for the last year. Took that off and reconnected direct to battery.
Yeah!!:D everything fired up. There was a fault in the isolator. Being only 12 months old I thought it would have been OK. Will get this replaced. You live and learn I suppose.
Thanks again for your quick response to my plea for help
Posted: Mon Mar 23, 2015 9:32 pm
by Simon Jones
You didn't mention the big on / off switch did you
. Glad you got it sorted ok.
Posted: Mon Mar 23, 2015 10:04 pm
by Bob
Just testing us.
Glad you're sorted.
