petrol tickover
B12ROCK
petrol tickover
Post by B12ROCK » Sun Mar 15, 2015 7:21 pm
Hi, just wondering about my tickover. It's a 2l petrol normally ticks over just over 1000 revs and just under a 1000 if I'm sat at a junction with my foot on the brake, it will pull forward if I take my foot off. Is that normal for an auto as I've never had one before so still learning how it operates.
Oh also I've fitted a digital temp gauge the sensor is fitted to a clip bolt on the rocker cover anyone know what sort of temp it will read it seems to read about 50 going along and rises to about 70 standing still, I'm thinking my thermostat might be suspect?
Cheers Brian
Gasy
Re: petrol tickover
Post by Gasy » Sun Mar 15, 2015 7:32 pm
Yes they do creep forward from a standstill
I've now got used to knocking it into neutral
And I now drop it down manually as slowing down ( with the hold button and then going into 2 and 1 gear manually with stick )
Think it's better for the torque converta or something to go into neutral at standstill
And using the gears to slow down is something I always do with my manual works van and it must save on brake pads with the auto bongo
Re: petrol tickover
Post by g8dhe » Sun Mar 15, 2015 8:51 pm
For the 2l FE-E engine the manual says Idle revs should be 800±20 RPM so it won't help being a bit on the high side.
B12ROCK
Re: petrol tickover
Post by B12ROCK » Mon Mar 16, 2015 9:11 pm
Cheers have to check the tickover then.
Re: petrol tickover
Post by teenmal » Tue Mar 17, 2015 11:34 am
Try for 700~800 (without lumpy tick over)that should cure the creep.
mikeWalsall
Re: petrol tickover
Post by mikeWalsall » Tue Mar 17, 2015 11:36 am
A point to remember ... when the air conditioning is on .. the tick over speed increases slightly ..
Poohbear
Re: petrol tickover
Post by Poohbear » Tue Mar 17, 2015 1:20 pm
Gasy wrote:Yes they do creep forward from a standstill
I'd rather replace brake pads than the gearbox :)
Re: petrol tickover
Post by haydn callow » Fri Apr 17, 2015 11:00 am
Temp sounds o.k. For a sensor in the position you mention....stat will be working fine once you get up to temp.....patrols do run very cool.
