Can anyone give me any advice/info re removing the injector pump from my 1995 diesel Bongo?
thanks
Removing Injector Pump
Re: Removing Injector Pump
1995 Ford Freda 2.5 TD 4x4 AFT
I did mine a while ago.
Hardest thing is locating the woodruff key in the crank shaft drive gear.
I am told that you can bolt the whole thing back in and think that the key is connected only to find that it is not.
Good luck with it.
Good luck with it.
Thanks for the replies, I will pass the info on to the guy thinking of doing this.
Excuse my ignorance but is the fuel pump the same as the injector pump?
Yes the fuel and injector pump are one and the same.Morvern wrote:Thanks for the replies, I will pass the info on to the guy thinking of doing this.
Not a job for the faint hearted though.
