aerial Replacement
Posted: Thu Mar 12, 2015 10:58 am
by khisanth
Hi i noticed that the plastic on my aerial mount is broken on my 1997 Diesel
It looks very similar to this maybe identical is hard to tell from the picture does anyone know where i can get a new replacement from including the rubber seal aswell or an alternative product
http://www.ebay.co.uk/itm/Mazda-Bongo-F ... 3aa4a102c7
cheers in advance
Re: aerial Replacement
Posted: Thu Mar 12, 2015 1:44 pm
by Simon Jones
Have you got AFT or tintop? The ebay aerial is suitable for the latter. Its also got some cracks on it.
Posted: Thu Mar 12, 2015 3:54 pm
by khisanth
The roof does raise but it does not loom like the ones on the parts list it does look like that one. Am after one without cracks or an alternative item
Posted: Thu Mar 12, 2015 7:44 pm
by Bob
Forty five quid from the Bongo Shop.
Posted: Thu Mar 12, 2015 7:54 pm
by Simon Jones
Have you got an aftermarket roof: manual lift rather than electric? You'd probably have to order one from Mazda or get Ian to source it as the one in the club shop will only fit van with an AFT.
Posted: Thu Mar 12, 2015 11:38 pm
by blobber
Never knew they retracted on a tintop..............mine doesn't.
Posted: Thu Mar 12, 2015 11:44 pm
by khisanth
its not a tin top its a manual lift roof not autolift..
If there is a way to maybe fix the cracks and renew the gasket that might fix the problem also
Posted: Fri Mar 13, 2015 12:03 am
by Bob
I'm guessing yours started life as a Tin Top and has been fitted with an 'After Market' lift up roof.
This ariel looks like a Tin Top one to me.
Posted: Fri Mar 13, 2015 12:06 am
by Simon Jones
So it's a tintop with a tintop aerial and an aftermarket roof
. There is very little demand for that aerial (compared to the AFT) so you'd be lucky to find a new one in stock. I'm sure Ian could try to get one direct from Mazda or you may just have to contact some of the breakers to see if you can find a good used one.
Posted: Fri Mar 13, 2015 12:36 am
by khisanth
Would the aft one fit in its place. I basically need to stop the leak
Posted: Fri Mar 13, 2015 12:43 am
by Simon Jones
No. Very different.
AFT is fitted above the B pillar and folds up and down on a pivot:
Tintop is fitted above the A pillar and retracts down inside (unless you're Blobber and don't use it enough to stop it seizing up
If its leaking, you could consider putting some sealant on it or glue the damaged parts.
If you're anywhere near Bury, try this place who are breaking a late model tintop (not sure if there is much left of the drivers side to rescue the aerial):
http://www.ebay.co.uk/itm/MAZDA-BONGO-2 ... 3cf45f595b
Here's a 2000 model being broken:
http://www.ebay.co.uk/itm/2000-w-mazda- ... 4ae627c6f0
Posted: Sat Mar 14, 2015 12:21 am
by blobber
None taken Simon
p.s. It wuz like that when I bought it
Posted: Sun Mar 15, 2015 5:05 pm
by Titan1995
I have a tin top that I am breaking...the aerial is in good order.
PM me if you still need one
