aerial Replacement
Moderator: Ian
khisanth
aerial Replacement
Post by khisanth » Thu Mar 12, 2015 10:58 am
Hi i noticed that the plastic on my aerial mount is broken on my 1997 Diesel
It looks very similar to this maybe identical is hard to tell from the picture does anyone know where i can get a new replacement from including the rubber seal aswell or an alternative product
http://www.ebay.co.uk/itm/Mazda-Bongo-F ... 3aa4a102c7
cheers in advance
Re: aerial Replacement
Post by Simon Jones » Thu Mar 12, 2015 1:44 pm
Have you got AFT or tintop? The ebay aerial is suitable for the latter. Its also got some cracks on it.
khisanth
Post by khisanth » Thu Mar 12, 2015 3:54 pm
The roof does raise but it does not loom like the ones on the parts list it does look like that one. Am after one without cracks or an alternative item
Post by Bob » Thu Mar 12, 2015 7:44 pm
Forty five quid from the Bongo Shop. :wink:
Post by Simon Jones » Thu Mar 12, 2015 7:54 pm
Have you got an aftermarket roof: manual lift rather than electric? You'd probably have to order one from Mazda or get Ian to source it as the one in the club shop will only fit van with an AFT.
blobber
Post by blobber » Thu Mar 12, 2015 11:38 pm
Never knew they retracted on a tintop..............mine doesn't. #-o #-o
Alan & Dot
Yes sir, I can Bongo !!
khisanth
Post by khisanth » Thu Mar 12, 2015 11:44 pm
its not a tin top its a manual lift roof not autolift..
If there is a way to maybe fix the cracks and renew the gasket that might fix the problem also
Post by Bob » Fri Mar 13, 2015 12:03 am
I'm guessing yours started life as a Tin Top and has been fitted with an 'After Market' lift up roof.
This ariel looks like a Tin Top one to me. :)
Post by Simon Jones » Fri Mar 13, 2015 12:06 am
So it's a tintop with a tintop aerial and an aftermarket roof :). There is very little demand for that aerial (compared to the AFT) so you'd be lucky to find a new one in stock. I'm sure Ian could try to get one direct from Mazda or you may just have to contact some of the breakers to see if you can find a good used one.
khisanth
Post by khisanth » Fri Mar 13, 2015 12:36 am
Would the aft one fit in its place. I basically need to stop the leak
Post by Simon Jones » Fri Mar 13, 2015 12:43 am
No. Very different.
AFT is fitted above the B pillar and folds up and down on a pivot: http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Tintop is fitted above the A pillar and retracts down inside (unless you're Blobber and don't use it enough to stop it seizing up :) )
If its leaking, you could consider putting some sealant on it or glue the damaged parts.
If you're anywhere near Bury, try this place who are breaking a late model tintop (not sure if there is much left of the drivers side to rescue the aerial): http://www.ebay.co.uk/itm/MAZDA-BONGO-2 ... 3cf45f595b
Here's a 2000 model being broken: http://www.ebay.co.uk/itm/2000-w-mazda- ... 4ae627c6f0
blobber
Post by blobber » Sat Mar 14, 2015 12:21 am
None taken Simon :x :lol:
p.s. It wuz like that when I bought it :(
Alan & Dot
Titan1995
Post by Titan1995 » Sun Mar 15, 2015 5:05 pm
I have a tin top that I am breaking...the aerial is in good order.
PM me if you still need one
Return to “Pimp My Bongo”
