coolant alarm fitting
silage
Post by silage » Fri Feb 27, 2015 9:55 pm
i am in the process of buying my first Bongo and would like to fit a low level alarm.
Could the more wise tell where i could get one and how easy is it to fit?
thanks
Silage
" The harder you work, the richer you die"
97 4WD 2.5 TD
G0JZW
mikeWalsall
Re: coolant alarm fitting
Post by mikeWalsall » Fri Feb 27, 2015 10:21 pm
There are several 'cheapo' versions on eBay .. but you pays your money so it's your choice ..
But for quality .. service and personal back up ...
http://www.coolantalarm.co.uk/shop/inde ... roductId=3 ...
... Is generally a good choice and favored by many owners ..... ( I have one) ..!!
Post by Bob » Fri Feb 27, 2015 10:46 pm
Hi Silage, and welcome to the Forum.
We have on of Haydn's, as shown above, and it has just saved us from a very expensive repair.
Used Bongy on Monday last - all fine.
Turned key to go to work Thursday - alarm sounds. Have a look - no coolant.
Flat Bed to garage, bleed hose leaking, all fixed.
No alarm would have resulted in a blown head - Get the good one, oh yes, and pay attention to it when it does its job. There are so many tales of it being ignored. #-o
Post by Bob » Fri Feb 27, 2015 10:48 pm
Re-read post, it is a fairly easy DIY fit or just ask your garage to do it.
While I'm on a roll do, please, use a Bongo Savvy garage for any work involving the cooling system, or bone up on it if you are a handy DIYer.
Enjoy your Bongo and the Forum & Club. :D
silage
Post by silage » Fri Feb 27, 2015 11:51 pm
Hi gents thank you all. Silage :D
97 4WD 2.5 TD
G0JZW
Post by Bob » Sat Feb 28, 2015 12:00 am
If you order direct from the manufacturer there is a secret code word to get Forum users a small discount. :wink:
helen&tony
Post by helen&tony » Sat Feb 28, 2015 4:56 am
I can only add to the above and say that the alarm is fail-safe, and the alarm is loud, and it's saved my bacon twice, and one time it enabled me to stop in seconds, and the first time was on the drive!
Gasy
Post by Gasy » Sat Feb 28, 2015 8:39 am
Engine temp alarm £35 fleebay
http://www.ebay.co.uk/itm/111052553849? ... EBIDX%3AIT
Low coolant alarm £15 fleebay
170927068334
http://www.ebay.co.uk/itm/170927068334? ... EBIDX%3AIT
I've had both for nearly 2 years now
No probs
cmm303
Post by cmm303 » Sat Feb 28, 2015 8:51 am
silage wrote:Hi
thanks
Silage
Easy to fit. Fitted mine as a complete Bongo novice (so where's the engine #-o ) in a couple of hours and most of that was spent working out how/where to pick up switched live 12v feed.
Chris with BertieB
Gasy
Post by Gasy » Sat Feb 28, 2015 9:04 am
Piggy back fuses make picking up a live feed easy
http://www.ebay.co.uk/itm/321088780930? ... EBIDX%3AIT
cmm303
Post by cmm303 » Sat Feb 28, 2015 9:06 am
Gasy wrote:Piggy back fuses make picking up a live feed easy
=D>
Fuse 10 does instrumentation.
Chris with BertieB
silage
Post by silage » Sat Feb 28, 2015 10:55 am
Thanks for all the support, piggy back fuses, never heard of them till now! sounds like a plan.
The Bongo we looked at is a 2.5 D 1997 with 63,000 on the clock, fresh import, some minor body touch up required but for age i did'nt think it was too bad. Cambelt, serviced, and undersealed, mot, with 3 mouth warry on engine( usual dealer one) and six mouth on all appliances in new full side conversion.
One thing i have noticed with all the bongos i have looked at whilst deciding is the main front light seem to look cloudy not clear? i know it has passed the mot so must be legal but would like other views with more experience of the Bongo beast.
silage
97 4WD 2.5 TD
G0JZW
Post by haydn callow » Sat Feb 28, 2015 11:05 am
The lens is plastic and can be restored/ polished.
Post by teenmal » Sat Feb 28, 2015 11:18 am
silage wrote:Hi
thanks
Silage
A lot of dealers /traders are installing this type of unit for about £45/50 Fitted.
http://www.ebay.co.uk/itm/121532137275? ... EBIDX%3AIT
Post by haydn callow » Sat Feb 28, 2015 6:31 pm
Silage has gone for one of ours, as indeed do most of the major dealers.
