Window
hampshire hog
Window
Post by hampshire hog » Mon Feb 16, 2015 9:01 am
Drivers side window stuck down,any idea what it can be,thanks.
Re: Window
Post by mikeonb4c » Mon Feb 16, 2015 9:22 am
Most likely switch or wire break in harness. Has been intermittent before going completely?
hampshire hog
Re: Window
Post by hampshire hog » Mon Feb 16, 2015 9:45 am
have managed to get window back up,but now driver and passenger windows wont go down.
Re: Window
Post by Bob » Mon Feb 16, 2015 11:38 am
As Mike says, most likely a break where the loom passes from the pillar into the drive's door.
Strip off the outer insulation and you may well spot the damaged wire/s.
Simple diy or new looms can be bought, but not cheap.
Re: Window
Post by francophile1947 » Mon Feb 16, 2015 4:32 pm
On mine it was the thick black wire, in the loom between door and frame, that had broken.
al & chris
Re: Window
Post by al & chris » Mon Feb 16, 2015 8:19 pm
If the window try to move when you press switch or just make a clunk. Might jut be the the window rubbers that the windows slide down through need lubricating. Ours has times when they get stuck. I used some scilicon spray last time, not sure what others use.
