4x4 alloys and diff winding
Moderator: Ian
Tanuki
Post by Tanuki » Tue Feb 10, 2015 11:11 pm
Hi I've been warned that fitting 18" RX alloys to my 96 4x4 can cause the diffs to wind up so I have a few questions.
To the best of my knowledge RX wheels are the same all the way round correct?
If I fitted these and kept the same rolling radius as the standard 15" wheels would I be right in thinking how can this possibly damage my diff?
How can you tell if you have a normal diff or an LSD?
And follow on from above is it possible to cause diff winding if I have an LSD bongo?
Sorry if these questions seem stupid but I have done a search.
Edit-spelling
Re: 4x4 alloys and diff winding
Post by Bob » Tue Feb 10, 2015 11:33 pm
With the same size wheels and tyres all round I can't see how this would effect the diffs. :?
Tanuki
Post by Tanuki » Tue Feb 10, 2015 11:39 pm
This was my thinking especially if I keep the same rolling radius as standard.
I'm not sure this is possible though with 18"s
Apparently to keep the same rolling radius as standard you would need
225/45/18 rear
205/55/18 front
Post by Simon Jones » Tue Feb 10, 2015 11:50 pm
Yep, as long as all four are same rolling circumference you can't get diff wind up. What is not widely known is that tyres of the same size can actually be a different circumference from different manufacturers. Another reason why mixing different types and brands of tyres is not wise idea.
Tanuki
Post by Tanuki » Tue Feb 10, 2015 11:54 pm
Interesting, so you would need to use the tyre sizes I put above to keep the same rolling radius as the standard tyre...
Or put your diff at risk :shock:
Tanuki
Post by Tanuki » Tue Feb 10, 2015 11:56 pm
This was the converter I used
http://www.tyresizecalculator.com
Converting from:
195/70/15 front
215/65/15 rear
Post by Simon Jones » Wed Feb 11, 2015 12:05 am
Just fit same size all round :). Doesn't necessarily have to match the original rolling circumference but if it did then it would keep the gearing and speedo reading standard.
andyb36
Post by andyb36 » Wed Feb 11, 2015 8:51 am
#-o well ive had my rx8 wheels on for 7 years now
the only whining I hear is her is the passenger seat because the music is too loud lol :lol:
all my tyres are the same size and pumped up to 48 psi
if you want to know the make and size - let me know
I don't know the name and size off hand - but ive stuck with the same name and size as I had on originally
always served me well
8)
lol - this pic will do its rounds now
Post by francophile1947 » Wed Feb 11, 2015 4:53 pm
Fit 225/45x18 all round - no need for different sizes on front and rears.
Just make sure that the loading is at least 96 - most tyres of that size are below 96.
Post by Northern Bongolow » Wed Feb 11, 2015 7:29 pm
it doesnt matter if its a lsd, but if you need to know/want to know, jack up the back wheels, turn one wheel, if the other side goes the opposite way its a standard diff, if it goes the same way its a lsd
mitch
Post by mitch » Wed Feb 11, 2015 8:46 pm
Hello mate
I had RX8 wheels on my last Bongo and they look really cool.
I have one and tyre in the swaps section.
In all honesty my experience showed that you only have to clip a curb and you take a big chunk out of the tyre wall.
The AWD was less responsive too.
They look great but are not the best for getting off wet festival grounds etc.
I would not have them on again!
Regards
Tony x
Post by Tony x » Wed Feb 11, 2015 11:14 pm
Another way to tell if the diff is limited slip is to look for a yellow paint blob on it.
The lsd takes a slightly different oil to the normal and front diffs
blobber
Post by blobber » Wed Feb 11, 2015 11:47 pm
I agree that RX8 wheels look good but the ride quality suffers, i've had these 15" alloys on for years without loosing the comfort of the origionals.
Alan & Dot
Yes sir, I can Bongo !!
rustyp
Post by rustyp » Fri Feb 13, 2015 1:17 am
I have fitted 17" wheels with a slightly larger rolling radius tyres and it is the best modification I have made, the gearing is raised for better more relaxed cruising and there is less body roll.
Tony x
Post by Tony x » Fri Feb 13, 2015 8:09 pm
Rustyp - that's exactly what we did and it worked well for us to.
Return to “Pimp My Bongo”
