REAR BULB HOLDER
REAR BULB HOLDER
BOTTOM REAR BULB HOLDER IS COMPLETELY CORRODED WHERE DO I GET REPLACEMENT
Re: REAR BULB HOLDER
MAZDA,EBAY,SCRAPPIE,MOTOR FACTORS ETC ETC.
GOOD LUCK.
GOOD LUCK.
- Simon Jones
I've heard of strange things in bottoms but never a corroded bulb holder
. Is it the rear light cluster (brake, indicator, sidelight) that is affected? if so, you will need the complete light cluster & there are 3 types so you best bet is to find a breaker on ebay. Expect to pay £40 - £60 for complete unit.
Alternatively, are you referring to rear fog light dangling below the bumper? If it's that, then any motor parts supplier will have one from about £5.
Get some WD40 on the shift key too. The use of caps is considered as being very SHOUTY
- helen&tony
The rear bulb holders (3 off)are on a loom, you can cut the offending corroded holder from the loom and connect a new holder to the loom.
I done one a few months ago, cant remember what holder I used it was one (not labelled) from the workshop.
If I find the origin of the holder I will PM you the details.
