Page 1 of 2
rear door ladder
Posted: Mon Jan 26, 2015 6:19 pm
by grey fellah
hi, anyone got an ingenious idea how 2 fit a mk1 terzo rear ladder (where you remove the left hand horizontal handle on the rear door) on a 2002 rear door (no handles)
Re: rear door ladder
Posted: Mon Jan 26, 2015 6:22 pm
by Simon Jones
You can't
. You can fit late style ladder to earlier tailgate with handles, but not handle-mounted type to later style tailgate.
The later style clamp over the bottom of the tailgate:
Posted: Mon Jan 26, 2015 6:44 pm
by Gasy
Self tapping screws then
Posted: Mon Jan 26, 2015 7:29 pm
by dom_e
Rivnuts may be safer than self tappers.
Posted: Mon Jan 26, 2015 8:07 pm
by Simon Jones
Into plastic trim panel with light fittings? Fine as long as never used to to climb on or the tailgate is never slammed shut
The facelift tailgates are different under the trim panels so the only practical solution to fit that ladder to that vehicle would be to swap the whole tailgate.
This is the mounting point for the early ladder:
Posted: Tue Jan 27, 2015 9:52 am
by grey fellah
thanks for the repies, guessed it wasn"t an easy fix, not going to drill rear door, so next request, anyone know if i can get hold of the bottom clamps, thanks
Posted: Tue Jan 27, 2015 10:26 am
by Simon Jones
You need to get the correct ladder. The one you have is shorter that the correct one as can be seen if you compare the length in these two pictures:
I've got two in the shed which are due to be vapour blasted and powder coated back to new condition as i did with this one. However, I've got a few more pressing things to attend to first so it won't be done for a few months yet but I can give you a shout nearer the time if you're still looking.
Posted: Tue Jan 27, 2015 9:18 pm
by grey fellah
thanks simon for your lnfo, i will look for a mk2 ladder & move on the mk 1 set i bought on e bay after a few drinks on a friday night ! lesson learnt !
Posted: Wed Jan 28, 2015 4:38 pm
by situbusitgooddog
Please let me know when you've got round to doing up one of those MK2 ladders! Looks fantastic blasted and coated - have just fitted a solar panel so having a ladder on the back could prove useful for keeping it clean etc. Thanks
Posted: Wed Jan 28, 2015 8:35 pm
by Simon Jones
Will do
Posted: Thu Jan 29, 2015 9:05 pm
by stuc
Are you able to climb up those ladders or are they for show?
Posted: Fri Jan 30, 2015 1:31 am
by Simon Jones
Posted: Mon Feb 02, 2015 12:07 am
by garethjr
One of those ladders would be really useful when I want to put surf boards on the roof, but can the roof take a person's weight moving around on top? I would need to get to the front roof bar to tie the boards down. I'm only little, so I don't weigh too much!
Posted: Mon Feb 02, 2015 9:03 am
by Simon Jones
I'm relatively light but wouldn't risk getting on the roof. If it were me, I'd get a cheap telescopic ladder like this so you could access this from any side:
https://www.buydirect4u.co.uk/product/d ... tAodLgEAdA
Posted: Mon Feb 02, 2015 9:34 am
garethjr wrote:One of those ladders would be really useful when I want to put surf boards on the roof, but can the roof take a person's weight moving around on top? I would need to get to the front roof bar to tie the boards down. I'm only little, so I don't weigh too much!
Don't even think about it
