rear door ladder
Moderator: Ian
grey fellah
rear door ladder
Post by grey fellah » Mon Jan 26, 2015 6:19 pm
hi, anyone got an ingenious idea how 2 fit a mk1 terzo rear ladder (where you remove the left hand horizontal handle on the rear door) on a 2002 rear door (no handles)
Re: rear door ladder
Post by Simon Jones » Mon Jan 26, 2015 6:22 pm
You can't :). You can fit late style ladder to earlier tailgate with handles, but not handle-mounted type to later style tailgate.
The later style clamp over the bottom of the tailgate:
Gasy
Post by Gasy » Mon Jan 26, 2015 6:44 pm
Self tapping screws then
dom_e
Post by dom_e » Mon Jan 26, 2015 7:29 pm
Rivnuts may be safer than self tappers.
Beyond A to B
Post by Simon Jones » Mon Jan 26, 2015 8:07 pm
Into plastic trim panel with light fittings? Fine as long as never used to to climb on or the tailgate is never slammed shut
The facelift tailgates are different under the trim panels so the only practical solution to fit that ladder to that vehicle would be to swap the whole tailgate.
This is the mounting point for the early ladder:
grey fellah
Post by grey fellah » Tue Jan 27, 2015 9:52 am
thanks for the repies, guessed it wasn"t an easy fix, not going to drill rear door, so next request, anyone know if i can get hold of the bottom clamps, thanks
Post by Simon Jones » Tue Jan 27, 2015 10:26 am
You need to get the correct ladder. The one you have is shorter that the correct one as can be seen if you compare the length in these two pictures:
I've got two in the shed which are due to be vapour blasted and powder coated back to new condition as i did with this one. However, I've got a few more pressing things to attend to first so it won't be done for a few months yet but I can give you a shout nearer the time if you're still looking.
grey fellah
Post by grey fellah » Tue Jan 27, 2015 9:18 pm
thanks simon for your lnfo, i will look for a mk2 ladder & move on the mk 1 set i bought on e bay after a few drinks on a friday night ! lesson learnt !
situbusitgooddog
Post by situbusitgooddog » Wed Jan 28, 2015 4:38 pm
Please let me know when you've got round to doing up one of those MK2 ladders! Looks fantastic blasted and coated - have just fitted a solar panel so having a ladder on the back could prove useful for keeping it clean etc. Thanks
Post by Simon Jones » Wed Jan 28, 2015 8:35 pm
Will do ;)
stuc
Post by stuc » Thu Jan 29, 2015 9:05 pm
Are you able to climb up those ladders or are they for show?
Post by Simon Jones » Fri Jan 30, 2015 1:31 am
Fully functioning & pretty sturdy. On my previous Bongo fitted with the full roof rack I used the ladder to get the awning & contents of roof bag on & off.
While on the current van I use it for the spare wheel when on long journeys.
garethjr
Post by garethjr » Mon Feb 02, 2015 12:07 am
One of those ladders would be really useful when I want to put surf boards on the roof, but can the roof take a person's weight moving around on top? I would need to get to the front roof bar to tie the boards down. I'm only little, so I don't weigh too much!
:lol:
Gareth
1999 2.5V6 AFT
Post by Simon Jones » Mon Feb 02, 2015 9:03 am
I'm relatively light but wouldn't risk getting on the roof. If it were me, I'd get a cheap telescopic ladder like this so you could access this from any side: https://www.buydirect4u.co.uk/product/d ... tAodLgEAdA
Post by mikeonb4c » Mon Feb 02, 2015 9:34 am
garethjr wrote:One of those ladders would be really useful when I want to put surf boards on the roof, but can the roof take a person's weight moving around on top? I would need to get to the front roof bar to tie the boards down. I'm only little, so I don't weigh too much!
:lol:
Don't even think about it [-X
Return to “Pimp My Bongo”
