Hello folks
just fitted a cd changer a thought would share tip
sorry if teaching to suck eggs
under the dash behind the glovebox their is a brace that is much like a
scaffold pole
if you buy 2 U-Brackets (50mm) as you would use on large arial masts and stuff
they fit around the bar and with a small amount of adjustment fit the
plastic bracets that are supplied with most cd changers
then when fitted, using a bit of skill you can adjust the position
so that the door that accepts the magazine is just in the gap
from the top of the back of the glovebox and the dash
meaning you can open the glovebox and change the cd's
worked very well for me
very pleased with result as so neat and concealed
Cheers all
Tip for cd changer and stuff
- dandywarhol
gap above glovebox
It also fits a sony playstation nicely.
and inverter
best regards
Jacob
best regards
Jacob
