diesel knocking
fieldy1978
diesel knocking
Post by fieldy1978 » Fri Dec 26, 2014 4:27 pm
So i have just ordered a dti mount do i can adjust the diesel pump accurately. I find it very strange they have no zero marks for a default timing. Anyway just found something rather strange that I'm looking for a workaround or replacement. It has been repaired load by the looks of it but if i can bypass then i will. Please see attached pic. Not sure a)what it is and b) what it does but pipes come from diesel pump and go to nothing! !
http://i265.photobucket.com/albums/ii22 ... 145957.jpg
Re: diesel knocking
Post by Northern Bongolow » Fri Dec 26, 2014 11:43 pm
they are the cold start solenoids, the act on the pump via the vac pipes and diaphragm, they do look in a bit of a mess and the crappy non vac pipe wont help as it will suck flat when warm.
heres how they should be piped up.
http://lushprojects.com/bongopartsmk2/c ... 1of02.html
the pipes go to 24-8002 on here.
fieldy1978
Re: diesel knocking
Post by fieldy1978 » Sat Dec 27, 2014 12:09 am
Thanks for the great links. When it's running properly i shall replace it all. Hoping to get the dti tomorrow for some fine tuning. Otherwise if it's not pump timing then it's going to be engine out job!
Titan1995
Re: diesel knocking
Post by Titan1995 » Tue Dec 30, 2014 3:58 pm
Just a thought....as this happened to me....check that you don't have a broken rocker.
