I was wondering if there was a way to power the rear blinds from the switches in the back without the key in the ignition ?
Thanks in advance
Rear blinds
- Simon Jones
Re: Rear blinds
Fuses 6 and 7 are for the rear blinds so you can rewire them to go to the leisure battery (if fitted) or to a permanent live on the main battery.
Some more info about wiring to LB: http://igmaynard.co.uk/bongo/forum/view ... re#p622074
http://igmaynard.co.uk/bongo/forum/view ... re#p581954
http://igmaynard.co.uk/bongo/forum/view ... se+leisure
Re: Rear blinds
Thats great thanks for the info
- haydn callow
Re: Rear blinds
Are you aware that the blinds are designed to be operated by the switches or manually by hand. Just pull em down and push them up. Saves the battery for more important things.
