How do you remove rear plastic number plate panel?
I can see two bolts by the number plate light, but how is the rest held in place and how do you remove the handles?
- Simon Jones
Re: How do you remove rear plastic number plate panel?
Remove: handles, number plate, number plate lights, door release handle (I think) and the nuts at the far edges of the tailgate on the inner side. Each handle is held on with four bolts that are revealed by carefully prying off the cover pieces.
This diagram should help: http://lushprojects.com/bongopartsmk2/c ... 2of02.html
Thanks Simon.
