Heater Switch
mcbainia
Heater Switch
Post by mcbainia » Tue Dec 16, 2014 7:24 am
Morning.
The heater-pointer switch in my Bongo appears to have died....The heating system works fine - you can get hot or cold air out and you have the option of off, 1, 2, 3 or 4 but the 3rd dial on the right hand side of the unit doesn't work. It goes around to all the different settings (Legs, face, Windscreen etc) but no matter what you do, the air blasts out of the face setting. This wasn't an issue during the summer months but now that there's an inch if ice on my windscreen, it's becoming rather tiresome.
Does anyone know anything about these units? Is it a whole new unit I need or is it just a dial?
Regards,
Craig
You can lead a horse to water but you cannot make it swim
Gasy
Re: Heater Switch
Post by Gasy » Tue Dec 16, 2014 7:28 am
Have a look by the drivers feet there is a metal link that moves the heater position
Known the fall out break regually
Sure it's driver side but check both
Left of drivers feet
Re: Heater Switch
Post by g8dhe » Tue Dec 16, 2014 12:14 pm
mcbainia
Re: Heater Switch
Post by mcbainia » Tue Dec 16, 2014 12:17 pm
Cheers for that folks - saved me a trip to the garage!
Where is that photo taken from? Is it from the drivers foot well?
Craig
Re: Heater Switch
Post by g8dhe » Tue Dec 16, 2014 1:50 pm
Yes kneel outside and look in towards the air box under the console between driver and passenger seats.
mcbainia
Re: Heater Switch
Post by mcbainia » Tue Dec 16, 2014 1:52 pm
Perfect,
I'll have look this evening and hopefully be frost free tomorrow!
Cheers,
the1andonly
Re: Heater Switch
Post by the1andonly » Wed Dec 17, 2014 11:32 pm
Mine pops out regularly, the restraining loop broken many moons ago
are there any semi permament fixes to stop it popping out again.
ps tried various tie wrap methods
Gasy
Re: Heater Switch
Post by Gasy » Thu Dec 18, 2014 7:26 am
Can you not make a new one out of a coat hanger
Bend loops on the end to stop it popping out
