Converting my tin top
john787030
- Bongonaut
hi I have a bongo tin top and want to convert it to a motor home , where do I start? Any help appreciated.
Re: Converting my tin top
there are profesional converters around had my first tin top done by a company but there not in buisness now
- Simon Jones
Pop your location in your profile so folk can recommend some companies in your area. Alternatively you could convert it yourself if you have the tools and skills.
You can buy a kitchen pod for about £1000
Remove rear bench and bolt in place job done
A lot less than that............:-Gasy wrote:You can buy a kitchen pod for about £1000
http://www.ebay.co.uk/itm/MAZDA-BONGO-N ... 1436413571
That price is just for the base unit cupboard
No high side cupboard
No table
No electrics, 240 or 12
No battery charger , hook up
No cooker
No gas piprwork
No gas bottle
No sink
No water pump
No water butts
Just a large wooden box with a big hole in it
No table
No cooker
No gas piprwork
No gas bottle
No sink
No water pump
No water butts
Surely that's for all the components as the tranzwagon one's basic bit is £399?
"And comes as seen in the pictures,Fully Assemble " this is what the add reads
If you want a lifting roof I would just sell it and buy one as they cost a lot to fit.john787030 wrote:hi I have a bongo tin top and want to convert it to a motor home , where do I start? Any help appreciated.
Conversions can cost for £100 to thousands give us a better idea of what you need and we will show you some ideas
New Forest Terrier
I have a tin top with a full rear conversion. Its got its drawbacks but so does any design as Bongo's have limited space and tin top's lack the storage space a rising roof gives.
I would use it for a few camping trips and work out how you want to arrange the space. As you do not have a roof to sleep in, you sleep downstairs and the conversion needs to give you enough free space. I went for a rear conversion because I found one second hand and I wanted the full Bongo width to give some floor space.
A removable conversion is a good idea in a tin top. One that can be lifted out and put in an awning, giving you the full width and length. I had a Stimpson Explorer kitchen in a box that could be used in or outside the Bongo for several years. I only changed to the conversion when I found one with a fridge which is the best thing about it. Mine is operated from inside the bongo which I find a pain a lot of the time. I would prefer to be able to cook from outside and load the fridge after I have packed the Bongo. Its great though if its raining and you can sit inside with a coffee. Also you can go back to bed with the coffee on a really horrible morning.
Unless you get a real full conversion, I would not bother. Mine has the fridge and storage cupboard both useful. A two burner stove can be used just as easily on a sturdy bench and a sink has no real advantage over a washing up bowl. You can run a power cable through the gap in the tailgate for the electricals. I still cook outside a lot on a gas BBQ as I do want the ghosts of bacon butties haunting the Bongo.
New Forest Terrier
The first thing I did was to fit a leisure battery. You then have lights, window blinds and a powered cool box. All useful if you are camping with no power. With that comfort levels rise and are on your way to a motor home.
With mine I can manage a festival in relative comfort and be sure to have the power to start again.
- Jillygumbo
I have a tintop too. I've had a leisure battery fitted for the sockets, rear lights etc. I've also got a Fiamma 45s wind out canopy, although it does rattle while driving, despite best efforts. I camp on my own with the dog most of the time but sometimes need 8 seats. I replaced the rear bench seat with gull wing seats and leave one down withe the bed made up. That leaves space for a porta potty at the side- just. I have a Stimson explorer kit and think it's wonderful. I use a quechua base tent as my kitchen/storage area on site.
I would not bother converting a tintop or adding a roof. When the time comes I plan to get one with a roof and conversion but I'm in no rush. I now know exactly what I'll want at that time but Tintin is a good'un so I'll wait ...
Jillygumbo, Marvin & Lady
