Starting issue
malc_s
Starting issue
Post by malc_s » Sun Dec 07, 2014 4:40 pm
Good afternoon peeps,
Up until 13.00 today my 2.5 diesel has always started on the button, but today when I tried to start her the engine just turned over with no attempt to catch.
The Breakdown man reckons its the fuel pump as he cant smell any fuel? Anyway he couldn`t do anything about it?
So it looks as though its getting towed in tomorrow.
Any suggestions as to what could be the problem?
Thankyou
Malcolm
Malc
Gasy
Re: Starting issue
Post by Gasy » Sun Dec 07, 2014 4:57 pm
Diesel or petrol
Which ever you need to find out if the fuel is getting to engine
the laird
Re: Starting issue
Post by the laird » Sun Dec 07, 2014 5:11 pm
Check your getting power to the fuel pump solenoid on top of the fuel pump.if you are not sure how to check it on looking into the engine compartment on the top of the pump the solenoid should click when ign turned on or off
Re: Starting issue
Post by francophile1947 » Sun Dec 07, 2014 5:53 pm
Gasy wrote:Diesel or petrol
Original post says 2.5 diesel 8)
Diplomat
Re: Starting issue
Post by Diplomat » Sun Dec 07, 2014 6:32 pm
If it's not a fuel delivery problem it will be blowing clouds of unburt fuel out of the exhaust.
It's that time of the year when they definitely won't start with no active glow plugs.
Frank
They flew, I took up naturism
Re: Starting issue
Post by Simon Jones » Sun Dec 07, 2014 8:40 pm
I guess there is plenty of fresh diesel into the tank? When was the fuel filter last changed? You could try some Cold Start sprayed into the air intake which may bring it to life briefly. Otherwise, fuel cut off solenoid does sound like a possible culprit.
Re: Starting issue
Post by mikeonb4c » Sun Dec 07, 2014 9:47 pm
the laird wrote:Check your getting power to the fuel pump solenoid on top of the fuel pump.if you are not sure how to check it on looking into the engine compartment on the top of the pump the solenoid should click when ign turned on or off
Must admit the sudden onset makes you wonder about this possibility. Should be quick to rule it in/out.
malc_s
Re: Starting issue
Post by malc_s » Mon Dec 08, 2014 10:39 am
Thankyou for suggestions.
Just checked the fuel pump solenoid ( at least I think I did ) and heard click when I turn ign. switch on/off.
Fuel Filter was changed less than year ago.
Would glowplugs breakdown so suddenly?
Malcolm
Malc
Re: Starting issue
Post by Ian » Mon Dec 08, 2014 11:18 am
malc_s wrote:Would glowplugs breakdown so suddenly?
It's not unknown for glow plugs to pop one by one. It will start OK with 3 operational plugs, it will even start Ok with 2 operational plugs, but these are then likely to go and then it won't start, This is what happened to me this time last year.
Re: Starting issue
Post by rita » Mon Dec 08, 2014 12:17 pm
The best thing to do is slacken an injector pipe and crank the engine (taking care to protect your eyes etc. If no fuel present remove the Stop Solenoid and make sure it is working, and the rubber seat has not come adrift or disintegrated blocking the fuel supply.
PS are you sure it doesn't need a drink.
Good Luck.
Tony x
Re: Starting issue
Post by Tony x » Mon Dec 08, 2014 3:32 pm
It's worth just checking no one has blocked your exhaust with a potato or something.
I say this as our old Bongo always started first time and then wouldn't start at all. I'd reversed into a soft mound of mud, completely blocking the exhaust.
malc_s
Re: Starting issue
Post by malc_s » Mon Dec 08, 2014 7:50 pm
Evening peeps- here is an update.
2nd breakdown man arrived to tow van back to my local dealership 321Away.
Before leaving he had a quick looksee, and sprayed some Cold Start into the air intake.
He tried turning it over a few times and a few more squirts and you have guessed it - nothing hapened.
He was just about to put van on back of low loader when he gave ign. one final turn, and blow me it fired up immediately.
Breakdown HQ informed him/me that if van breaks down again, tough, thats my lot.
So he took van on low loader to 321Away for them to check it out.
Julian at 321, checked fuel pump, removed and checked glowplugs, removed and checked banjo and all was well.
So good news Bongo back on road, bad news, we don`t really know what caused problem in first place.
Top marks to Julian for his time and knowledge, and for the 2nd breakdown man who did get it started.
Perhaps the first one couldn`t be bothered.
I`m now going to carry a can of Cold Start in van.
Thankyou for your response.
Chin Chin
Malcolm
Malc
