Lights!!! 2.0
Davidjamesinc
Lights!!! 2.0
Post by Davidjamesinc » Tue Nov 11, 2014 5:10 pm
Hi guys, looking for some tips. Just gone out to the Bongo 2.0 2002 and the only lights I've got are the front headlights. No rear or side and no dash/equipment lights. Something clicks when I turn them on but no illumination. Please help :?
Nullum Magnum Ingenium Sine Mixtura Dementiae Fuit.
http://www.davidjamesinc.com
Re: Lights!!! 2.0
Post by Bob » Tue Nov 11, 2014 10:36 pm
Possibly dirty contacts in the switch? A spray switch cleaner may do it.
Hope you find this soon.
Dogran
Re: Lights!!! 2.0
Post by Dogran » Wed Nov 12, 2014 1:17 pm
I had this problem in my 1996 Bongo and it turned out to be one of the relays inside the passenger side front wing. This has come up before, and this thread should help: http://igmaynard.co.uk/bongo/forum/view ... relay+wing
nth
Re: Lights!!! 2.0
Post by nth » Thu Nov 13, 2014 1:08 pm
Can we assume that you have checked all the fuses ?
95 2.5d 4WD AFT
Spencer54
Re: Lights!!! 2.0
Post by Spencer54 » Thu Nov 13, 2014 1:36 pm
Its the relay under the bonnet passenger side - to check it out for sure, swap them over you'll have two exactly the same. Top tip is to buy the generic Japanese relay for a couple of quid and avoid genuine Bongo ones that are either old or expensive or both.
http://www.ebay.co.uk/itm/JAPANESE-TYPE ... 27d75acbd5
If you can be bothered, you can cut the top bracket off (with the hole in it) and then they slide straight into the original relay and fit on as original and look original.
Had two in for months now, work like a charm.
Davidjamesinc
Re: Lights!!! 2.0
Post by Davidjamesinc » Thu Nov 13, 2014 2:42 pm
Thanks for the tips so far guys. I have a bit of time at the weekend so will have a try and post my results.
