Tyre positions
Posted: Sun Nov 09, 2014 4:10 pm
by al & chris
Just going to put winter tyres back on. Two have slightly more tread, should they go on the front or back. Same size tyre alround
Re: Tyre positions
Posted: Sun Nov 09, 2014 4:16 pm
by JoeC
Back.
Re: Tyre positions
Posted: Sun Nov 09, 2014 4:20 pm
by al & chris
Forgot to say we are 4wd.
Re: Tyre positions
Posted: Sun Nov 09, 2014 4:48 pm
by Gasy
Front as the front wear down quicker
And will soon match the rear
Also better to have best grip on front
IMHO
Re: Tyre positions
Posted: Sun Nov 09, 2014 5:45 pm
by al & chris
Just been looking on web and it does look like best tyres should always be on rear regardless of drive of vehicle.
Re: Tyre positions
Posted: Sun Nov 09, 2014 5:50 pm
by teenmal
The tyres with the most tread (grip) should always me fitted to the rear of a vehicle.
Re: Tyre positions
Posted: Sun Nov 09, 2014 6:21 pm
by Simon Jones
With 4WD you should try to keep the rolling circumferences as close to the same on all four corners so it's often recommended to swap front and rear occasionally to even out the wear and ideally replace all four tyres at the same time. This will reduce the chances of problems with the viscous coupling.
The advice these days is to have the deeper tread at the rear as others have mentioned.
Re: Tyre positions
Posted: Sun Nov 09, 2014 7:32 pm
by al & chris
Simon Jones wrote:With 4WD you should try to keep the rolling circumferences as close to the same on all four corners so it's often recommended to swap front and rear occasionally to even out the wear and ideally replace all four tyres at the same time. This will reduce the chances of problems with the viscous coupling.
Is the wear difference sufficient to cause a problem. Do you have to buy a new full set if you damage one tyre and the rest are half worn.?
Re: Tyre positions
Posted: Sun Nov 09, 2014 9:40 pm
by rita
If the VC is in good order and doing what it should there should not be a problem, the speed that the wheels revolve " on all wheels" of a motor vehicle are very seldom the same, that's why they fit differentials with Planetary Gears. Without this system you would be fitting New tyres every Week. :D
Re: Tyre positions
Posted: Sun Nov 09, 2014 9:58 pm
by Simon Jones
Not sure what the official tolerance is between difference in rolling circumference between front and rear. There may be some info in the owners manual.
What I do on my 4WD Volvo is start with a set of 4 new tyres and then keep an eye of out for a new and nearly new tyre on eBay so I've always one of each in the garage. If I need to get a new tyre when away from home, I've got a matching one available when I get back. Likewise, if I get an unrepairable puncture on a part worn tyre, I can fit a used one in its place.
At the moment, all 4 are getting low so I've got a set of winter tyres on steel rims going on and then I've got a few months to shop around for another set of new tyres for the spring. I'll then keep the best from the worn set as a backup for future use.
Re: Tyre positions
Posted: Thu Nov 13, 2014 7:29 pm
by al & chris
Tyers on now best ones on front as when I checked them only 2mm between them. Hopefully will make wear even so can replace all at same time.
Re: Tyre positions
Posted: Sat Nov 15, 2014 12:45 pm
by Idris
al & chris wrote:Just been looking on web and it does look like best tyres should always be on rear regardless of drive of vehicle.
Whoever (origionaly) wrote this does not drive where there are corners in a 4wd or FWD vehicle, they probably don't even drive ;)
The most solid proof I ever had was doing driver training in Albertvillle - vehicles set up with different tyre situationas and different chassis stifneses - the only one that wasn't drivable with care was one with bald front tyres - one with completly bald rear tyres handled like it had a pair of castors at the rear on a we track (they wanted to fit castors but insurance wouldn't let them) but could be made to mre or less where you wanted. Bald fronts anything over walking pace and you crashed.
Re: Tyre positions
Posted: Sat Nov 15, 2014 2:41 pm
by Simon Jones
It does seem like the advice has changed over the years. In the late 80's I worked as a tyre fitter as a summer job and the recommendation was always best tread on the front. I think the logic was that the majority of the braking load is on the front wheels and of course they determine which direction the vehicle goes in.
Re: Tyre positions
Posted: Mon Nov 17, 2014 11:47 am
by roosmith
Search youtube for the Fifth Gear test on tyres. It's not about grip to move forward, it's about grip to stop. You do not want to be heavy braking with a car with loads of grip at the front and none at the back, regardless of drive as that has nothing to do with it. You do an emergency manoeuvre and you'll swap ends and who knows what'll happen. The other way round, the back will stay in check, hopefully you won't loose control.
