Where is the roof controller fitted
jimmo62
Post by jimmo62 » Mon Nov 03, 2014 8:37 pm
Hi all
just wanted a clue as to where the roof computer is fitted, I can't quite work it out from the diagrams and I don't want to be pulling off trim etc in the wrong place. So any indications on were and how to access would be great
thanks
Jimmo
Re: Where is the roof controller fitted
Post by Bob » Mon Nov 03, 2014 9:11 pm
Not sure what you mean by the roof computer?
What exactly is the problem?
We're just in Nailsea and will help if we can.
Gasy
Post by Gasy » Mon Nov 03, 2014 9:19 pm
If you after that little control box thingy
Check the bongo wiring diagram threads in the sticks above
Or ask g8dhe who writes them he will know and can prob sort your problem
If no one pops in soon
I think it's tuck away behind a interior panel somewhere
jimmo62
Post by jimmo62 » Mon Nov 03, 2014 9:43 pm
Yep I want to get to the control box which appears from the wiring manual to be in the roof but it's a bit hard to be sure from the pictures.
No problem at present but I'm thinking about moving the control switch to raise/lower the roof to somewhere more convenient. So I want to connect into the wiring and I think doing that by the controller may be the easiest way
Post by Simon Jones » Mon Nov 03, 2014 9:43 pm
The control box is behind the rearmost panel on the drivers side.
jimmo62
Post by jimmo62 » Mon Nov 03, 2014 9:46 pm
Brilliant thanks Simon
Post by Simon Jones » Mon Nov 03, 2014 9:52 pm
Post by g8dhe » Tue Nov 04, 2014 12:25 am
Yup that's the location! Never seen mine as its behind the side conversion and will be a pig to get at if I ever need to :-(
