Just picked up my Bongo tonight (last night now I guess!) and spent ages and ages playing with it.
1. The R/N/S window has a smaller catch than all the others and won't open. (I don't want to force it.) Is this normal?
2. The middle O/S window is really loose - I can fairly easily put my fingers up between the window and the frame. (I found out cos I could hear a lot of noise through it!) I'm worried it will leak if I drive in the rain. What do I need to do to I fix it? All the fixings look OK.
3. Where's the spare wheel?!
4. Is there any way of getting the roof down manually? (Thinking ahead here!)
5. When I originally test drove the vehicle, there was a knocking sound coming from underneath that sounded like a loose exhaust or mudflap. The chap did say what it was - the rods or struts? Sorry, I forget and am not mechanically minded. Certainly a common problem. Anyway, they've been replaced. Coming home though, I thought I could hear the noise again. Will drive it again tomorrow over bumpy ground to see if it happens again. Hoping it's paranoia! If not, any ideas what it's likely to be?
Phew, I think that's it. For now anyway! Looking forward to your replies...
