Haydn Alarm LCD Bulb Change
Posted: Tue Oct 14, 2014 7:31 am
by Mark Elvin
Is is possible to change the bulb on the display an the LCD display? I'm a fussy bugger & it doesn't match the colour of the dash illumination.
Re: Haydn Alarm LCD Bulb Change
Posted: Tue Oct 14, 2014 7:57 am
Mark Elvin wrote:Is is possible to change the bulb on the display an the LCD display? I'm a fussy bugger & it doesn't match the colour of the dash illumination.
But....but.....but....the only time it's on is when you are likely to have other things on your mind?
Sorry, that's not an answer! It'll be interesting to see what the lca people say - so long since I fitted mine I can't remember.
Posted: Tue Oct 14, 2014 8:10 am
by Simon Jones
Most LCDs use surface mounted LEDs fixed to the PCB so changeable but only if you are experienced in working with s/m components.
Posted: Tue Oct 14, 2014 8:24 am
by Mark Elvin
Simon Jones wrote:Most LCDs use surface mounted LEDs fixed to the PCB so changeable but only if you are experienced in working with s/m components.
Good job we have a decent electronics manufacturing department!!!!
Posted: Tue Oct 14, 2014 9:50 am
by haydn callow
Are you talking about a Low Coolant Alarm or a TM2 temp alarm??
Posted: Tue Oct 14, 2014 11:32 am
by Mark Elvin
TM2 COMBINATION
Posted: Tue Oct 14, 2014 12:09 pm
by haydn callow
You could take the lid off and change the LCA alarm bulb if you can solder. Don't try and interfere with the TM2 bulb....but what's the point? It's only on for 1 sec when you switch on, any other time and you will spot the red amongst all your other lights.
Best advice...leave well alone.
Posted: Tue Oct 14, 2014 12:30 pm
by Mark Elvin
tHE LCD ILLUMINATION IS WHITE ALSO.
Posted: Tue Oct 14, 2014 2:39 pm
by haydn callow
You cannot change the LCD
Posted: Tue Oct 14, 2014 3:09 pm
by Mark Elvin
It's the illumination of the LCD I want to change. Not the warning light or LCD itself.
Posted: Tue Oct 14, 2014 3:41 pm
by haydn callow
Carnt be done
