![Pray [-o<](./images/smilies/eusa_pray.gif)
loss of power
loss of power
after buying and enjoying a bongo talked my first daughter into getting one great......talked 2nd daughter into getting one... it's now completely lost power done the last 10 miles @ 10 m.p.h put foot down and NO POWER at all my mechanic is pulling his hair out. this is a diesel 2 ltr w reg 2000 garage puts the machine on fix's the problems that come up STILL NO POWERts any IDEAS all welcome thanks ![Pray [-o<](./images/smilies/eusa_pray.gif)
Re: loss of power
Check the banjo filter it's a small filter/screen that is inside one of the pipe banjo bolt at the pump.also if this lack of power is evident try taking the filler cap off a see if you hear a thump or hiss it may be a blocked breather ,drive it with the cap off but put a cloth or likes to stop any fuel spillage ,hold it on with an elastic band.start with these two tries first ,fingers crossed n guid luck
Re: loss of power
Further alng in the same vain - regular fuel filter and if the fuel lines look perished, change all the rubber hoses - in tank filter/strainer is another ususal supect.the laird wrote:Check the banjo filter it's a small filter/screen that is inside one of the pipe banjo bolt at the pump.also if this lack of power is evident try taking the filler cap off a see if you hear a thump or hiss it may be a blocked breather ,drive it with the cap off but put a cloth or likes to stop any fuel spillage ,hold it on with an elastic band.start with these two tries first ,fingers crossed n guid luck
www.idriskis.com eco friendly skis
Re: loss of power
Banjo bolt is on the pipe into the filer head from the tank .previously I sais at pump I boo boo mistook ![Embarassed :oops:](./images/smilies/icon_redface.gif)
- Simon Jones
Re: loss of power
It'll be a 2.5 diesel (or there's a bit missingfoskett wrote: this is a diesel 2 ltr w reg 2000...
![Smile :)](./images/smilies/icon_smile.gif)
Check all the hoses and connections especially the vacuum hoses and solenoids.
