bottom hose not getting hot
steveandmary
Post by steveandmary » Sun Oct 05, 2014 4:20 pm
hi can anybody help me the bottom hose is not getting hot after 2 hours of trying to bleed the system using the sea saw method also the heating was getting hot at one point but then went cold,the rear heater is blowing cold air all the time thanks steve
wonkanoby
Re: bottom hose not getting hot
Post by wonkanoby » Sun Oct 05, 2014 5:08 pm
did you flush it out
is it leaking and your adding cold all the time
Gasy
Post by Gasy » Sun Oct 05, 2014 5:23 pm
Are you reving it
steveandmary
Post by steveandmary » Sun Oct 05, 2014 5:32 pm
hi yes reved it . still cud not get bottom hose hot . radiator top hose hot bottom cold
Gasy
Post by Gasy » Sun Oct 05, 2014 5:45 pm
Mine didn't get real hot but I could tell it had opend
steveandmary
Post by steveandmary » Sun Oct 05, 2014 6:11 pm
do you think i shud flush radiator. thanks
Post by Northern Bongolow » Sun Oct 05, 2014 8:13 pm
pm sent with phone number.
