Coolant Alarm +ve feed
Mark Elvin
Post by Mark Elvin » Wed Sep 24, 2014 6:36 am
Guys,
Can anyone suggest a place to take a +ve supply for the feed from for the coolant alarm please?
I believe the B/W wire on the diagnostics port in the passenger foot well is suitable, is this correct?
Re: Coolant Alarm +ve feed
Post by rita » Wed Sep 24, 2014 10:17 am
Into any ignition switched live feed from the SB.
You could also use one of these to make it easier.
http://www.ebay.co.uk/itm/Add-A-Circuit ... 486426a3ec
roosmith
Post by roosmith » Wed Sep 24, 2014 10:49 am
rita wrote:Into any ignition switched live feed from the SB.
They're a bit nifty, never seen them before.
Post by mikeonb4c » Wed Sep 24, 2014 2:57 pm
Nor had I. Only minor niggle I can see with them is will the fuse box cover still close with that lot in place?
jimmo62
Post by jimmo62 » Wed Sep 24, 2014 5:09 pm
Depends where the alarm is fitted but the switched positive in the radio loom is an easy point to access and if you have a loom converter to fit the Euro style stereos you can easily remove it to splice the wires in the warmth and comfort of your house....
Post by Simon Jones » Wed Sep 24, 2014 8:22 pm
Back of the instrument panel (thick red wires going off to the left of photo):
the1andonly
Post by the1andonly » Wed Sep 24, 2014 9:15 pm
I've used the piggy back fuse holders as suggested by Rita.
2 used one for coolant alarm and additional temp gauge.
dead easy to use and obvious. ie anyone can see its something added and not an in line fuse hiding somewhere.
there is a restriction to the number that can be fitted but then I would run a separate fusebox
